What is the CC of my valve releafs
Old Feb 7, 2002 | 10:40 PM
GOLD85's Avatar
im tryin to figure out my compresion ratio and i need to know the cc of the valve realeafs of my pistions. its a flat top pistion for a .030 over 400. it has your typical 4 half moon releafs.ive been told it like 10 cc, but i wanted others opinions. thanx
Old Feb 8, 2002 | 06:43 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
if they are about .160' deep.. it totals to about 6cc
not much more.
Old Feb 8, 2002 | 07:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, 6 cc is about as big as they get, about 4cc is the usual
Old Feb 8, 2002 | 03:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Is 4-6cc about right for a flat top slug that has 2 valve reliefs, or 4?
AJ
Old Feb 8, 2002 | 03:25 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
well both normally
the 2 valve relief pistons are normally .26 deep. that works out to about 6. If there are only 2 that are .16 deep.. your about 3.5 to 4.
Old Feb 8, 2002 | 06:29 PM
AJ_92RS's Avatar
Re: well both normally
HUH?!?!?!
So are you saying that 4 valve reliefs (which is what the Speed Pros I have are) would then be 12cc's if they're cut .26" deep? Since you said that 2 of them would have 6cc's of volume, then 4 would be 12cc's?
That's no different than if I would have just bought 12cc dished pistons!!!!!!
I hope that you made a typo, 'cause that sure don't sound right.
AJ
Old Feb 8, 2002 | 06:46 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
well.. yes but you rarely find 4 valve relief that are .26 deep
Because pistons like that are meant to go in ether way.
Speed pros are normally just a forged version of the factory piston. Same dimensions on everything.
Here is a pretty good example..
the trw 2256 is a forged 4valve relief piston with a volume of 6.1 cc. The trw 2417 has a single trough for the reliefs and it is 3.4 cc..but I think neither of these really have deep reliefs. Hiperf pistons from companies like Weisco and SRP are the ones meant for really big cams and hence have deep reliefs.
Based on my experience.
Now.. if you want to talk dish pistons.. or the 00 term.. reverse dome... they really start looking good when you have about a 48cc chamber. And that will screw up the airflow of a 23degree head. 18dgree are designed to have the flat chambers and reverse domes. Flow remains good.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
