tensioner question..
Old Feb 8, 2002 | 09:54 PM
JeffC1500TBI's Avatar
ok I got my beast down to the exhaust shop and got my link between the xover , cutout,cat & muffler hooked up.. muchmuch better.. I can hear myself talk now.. the only prob is now that the exhaust is a little quiter I can hear the tensioner squeaking on idle.. I don't know why cuz I had it appart to paint the aluminum part and the bearings seemed ok in it.. they guy there tells me they are worth like $150Canadian for a new tensioner /pulley.. I don't know if I can just oil it or what? anyhow other than that she seems to go pretty good.. even did a small burn out up to second gear and let her rip.. I don't want to be too hard on it yet but the engine builder told me to drive it like I'm going to drive it..
Old Feb 8, 2002 | 10:09 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
both gates and goodyear have replacement pulleys that will bolt into place on your existing spring loaded tensioner assy. a\c delco also has a pulley probably a bit more cash than the first 2 options-yours probably has a guide raised on each side of the pulley for the belt tracking-the new replacement will most likely be smooth-its ok-even the delco (read:factory g.m.) are smooth with no guides if i get a chance i'll edit this and put part #'s later tonite. seeya, frank
evilstuie
Jan 9, 2020 08:29 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
anesthes
Sep 30, 2015 07:48 AM
lakeffect2
Sep 7, 2015 03:52 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
