Spark advance at idle
Old Feb 7, 2002 | 08:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have it set at 6* and it shows 12* when plugged in on my Tech 1 is this right? i thought it was more like 14-16
Old Feb 7, 2002 | 09:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Depends on what parameters the ECM sees and determines to try to set it at.
You just put in a new cam, right? Probably less vacuum, could be interpeted as being a bit under load and the ECM retarding the timing some until the engine starts to get wound up.
This is where tuning your EPROM would become to be a big advantage, in the old days you could adjust the distributors, change weights and springs to curve your timing and advance, now you're at the mercy of what GM gave you ad tha parameter it's set to run with.
Old Feb 8, 2002 | 05:25 PM
Damon's Avatar
You need to unplug the timing wire before you set the base timing with a timing light. 6* BTDC base timing is a typical spec for a GM FI engine.
The timing your ECM is putting in is IN ADDITION to the base timing. So 6* base plus 12* ECM advance would be about 18* actual at idle. Again, that's pretty typical for an 80s era FI motor.
Old Feb 8, 2002 | 11:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yea I know. I set base with est disconnected and get it at six. I plug est back in and it shows then 12* on my tech 1.
eightsixseven
Dec 16, 2024 01:50 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Sep 4, 2015 07:57 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
