alternator woes
Old Feb 8, 2002 | 05:30 PM
cacktopher's Avatar
alternator woes
hey gurus, i checked the archives and found little help on my alternator problem. The problem is it's making weird noises (grinding, squeaks). What makes this worse is that i just purchased this alt. a month ago! It's been raining here in northern cali. Would rain be one of the culprits? BTW, the voltage hasn't dropped, so i'd say it's running normal despite the gawdawful noise. Oh, and the car is an '86 lg4. any advice is appreciated.
Old Feb 8, 2002 | 05:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is the belt totally tight?
Old Feb 8, 2002 | 05:38 PM
2vmodular's Avatar
bad alternator bearings?
Old Feb 8, 2002 | 05:50 PM
cacktopher's Avatar
yes, the belt is tight. About the bearings... is that something i can fix myself? I mean, that weird noise happened to the previous alternator and it just got progressively worse and worse, i fear that i'm losing this one too.
Old Feb 8, 2002 | 07:23 PM
2vmodular's Avatar
what belt drive system are you running on that engine? 1 big serpentine? or a few individual v-belts?
Perhaps the squeal is due to the belts always being wet, if so should quiet down when belts dry off. If its a big serpentine, the tensioner could be failing on you.
If alternator itself is determined to be culprit and if rebuilt alternator came with a lifetime warranty, bring it back to the store and get another. don't be too frustrated, it's not uncommon to have a "rebuilt" alternator fail shortly after it is installed.
if alternator does not have a warranty, you can replace the front bearing so long as you have access to an impact wrench to get the front pulley off the alternator. Back bearing is pressed in and requires special tools for replacement, can try adding some wheel bearing grease to it while you're in there.
Old Feb 9, 2002 | 01:06 AM
cacktopher's Avatar
thanks for the help! i bought a new belt and i tightened up the pully. It runs fine now :lala:
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
