Blue Smoke Gone!!!!!!!!!!!!!
Old Feb 9, 2002 | 07:42 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
My 305 was blowing blue smoke like a pipe. Thought for sure the motor was dead. I noticed the hose connected to the back of the manifold that went to the transmission was cracked. I took the hose off to replace it. My buddy came over and wanted to hear the car run so i started it without the hose on ....NO SMOKE..!!!!!!!!!!!!!!! as it turns out the diaphram in the vacuum modulator on the transmission is bad ....the manifold vacuum sucks up tranny fluid and spits it into the manifold............................................the hose was filled with tranny fluid....just thought i would share that ...........it never accured to me...
Rob
83
Old Feb 9, 2002 | 09:10 PM
Vader's Avatar
Great! You found your oil "leak". The only down-side is now you won't have all that extra upper-cylinder lubrication, but the cats and spark plugs should last longer.
Old Feb 9, 2002 | 09:18 PM
Car: 1983 Z28 Clone
Transmission: TH350
Yeah.. hey vader............i did what you said ....about pushrods..........well i only got 2 of them done.......they flow A LOT better. I was surprised at how easy that problem could have been fixed...think ill do the rest tomarrow .............car is gettin ready run...............i've never drivin a camaro either..i'm used to my monte...soo... this should be fun..i cant thank you enough..
Old Feb 10, 2002 | 07:09 PM
Jza's Avatar
Jza
That's fairly common with Turbo 350s. We got great deals on several trucks and a couple cars that the owners thought were toasted, but that modulator was the only problem.
Old Feb 10, 2002 | 09:23 PM
Car: 1983 Z28 Clone
Transmission: TH350
i wish somebody would have told me that it was common........................................hahahha.. its been bothering me for months...
Rob
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
