LG4 timing question
Old Feb 10, 2002 | 05:38 PM
Chevy83Z28's Avatar
LG4 timing question
Hey guys, I have a question. I set my base timing for my LG4 to 6 degrees BTDC (with the distributor connector disconnected, as the instructions say to do so.) Today I decided to play around a little, and advanced the base timing to 8 degrees BTDC. But I don't feel that much of a difference if any is even there--is the computer compensating for my advancing.. by retarding the timing the same amount? If so, what's the point in having a "base timing" anyway?
Old Feb 10, 2002 | 06:57 PM
ede's Avatar
ede
you might not of changed anything, as far as power output is concerened. the est advances the timing from the base setting.
Old Feb 10, 2002 | 09:54 PM
Chevy83Z28's Avatar
If the est advances the timing from the base setting, and I advanced the base setting 2 degrees, wouldn't the est be advancing the system by the base timing plus the extra 2 degrees?
RazorN8
Jan 7, 2022 11:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
