Bloated MSD's?? What happened? Pic>
Old Feb 11, 2002 | 01:07 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Check These out
I dont know what in the world caused this
The wires only have maybe 1000 miles on them or less
I'm running a MSD 6al and coil/cap/rotor
About half were either bloated or starting to bloat
What do you think caused this ??
BTW I had them far enough away from any heat for this to be a problem ....or atleast Should have been far enough away
Old Feb 11, 2002 | 09:01 AM
Vader's Avatar
It appears that either your wires are pregnant or they are destroying themselve from the inside out. A wire break or high resistance area, may be causing the creation of ozone. The insulation breakdown under the outer jacket and the gas pressure of the ozone may be causing the jacket to expand. I'll bet they don't last much longer. Either the wires were mechanically damaged on installation or in handling, or they were inferior to begin with. Lower resistance Packard wires might be a good place to start.
Old Feb 11, 2002 | 11:54 AM
sleeper's Avatar
If you're lucky they'll give birth and you'll have some little wires running around.
If they're only a month old I'd just take them back for a refund/exchange... they are obviously done for. Heat would not cause this... the silicone would just dry out and crack.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
