What are correct idle RPM's
Old Feb 12, 2002 | 02:17 PM
Matt_91RSTPI's Avatar
Can anybody list the correct idle RPM settings for a '91 305 TPI A4 while:
1) In Park
2) In Drive
3) In Neutral
I'd like to know the targets for when the car is cold and when it is hot if possible.
After de-carboning the IAC motor and TB I am running at 1500, 1000, and 2000 respectively. These values seem to drop about 250RPM after the car gets hot.
I know these settings are high and would like to lower them, but not so much that the car stalls when coming to a stop while in drive, which was what was happening before the IAC cleaning.
-Matt
Old Feb 12, 2002 | 03:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm not postive, but I think when warm in D around 600rpms. In park around 800rpms.
Old Feb 12, 2002 | 06:37 PM
lunas's Avatar
i get about 600 in drive and 1000 in park and nuetral
87 tpi auto
Old Feb 12, 2002 | 10:31 PM
Dick1234's Avatar
I get about 900 to a 1000 in park and a 600 in drive when cold
and 800 in park and 600 in drive when warm
Old Feb 13, 2002 | 12:17 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
ive got my idle turned down and im idling at 500 in drive and about 650-750 in park. it purrs at those levels, sounds really docile (sleeper)
Old Feb 13, 2002 | 12:36 PM
OK, thanks guys. I'm going to go through the IAC reset and see if I can get this more on target.
-Matt
Old Feb 13, 2002 | 04:46 PM
ChevyLuva3's Avatar
Besides the temperature, what would make a car idle so high like 1000rpm or more??
BTW mine idles like 600 or so.
Old Feb 13, 2002 | 05:23 PM
firbird's Avatar
what could make you idle that high? well a lot of things, 1 your in open loop and it is warming and the iac is letting in air, 2 your iac is stuck open, 3 vacume leak, 4 you have your min air set too high
xxx3man`
Sep 23, 2015 10:37 PM
Regal105
Aug 23, 2015 03:45 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
