how do u adjust ideling
Old Feb 12, 2002 | 04:37 PM
ihateallmustangs's Avatar
on a 89 rs /305 tbi? [thanks]
Old Feb 12, 2002 | 08:23 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Read the tech article
Check out the "Technical Articles" section. There is a decent article about adjusting your minimum idle (there is a torx screw under a cap you can punch out on your throttle body) and checking your TPS voltage (throttle position sensor). If you're more interested in fixing a rough idle, maybe start with looking at your IAC (idle air control) valve.
Old Feb 13, 2002 | 10:51 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
u adjust the idel with the idle screw on the front of the tbi. it is a star screw or wutever they are called
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
