trying to warm it up
Old Feb 13, 2002 | 09:44 PM
JeffC1500TBI's Avatar
ok well tonight roads where dry so I took the beast out for a drive.. it was 12 degrees F.. I had put card board in front of my rad to see if I could get it to warm up some more.. again I could only get it to 120 F.. must be that stewart pump along with the 180 robert shaw .. should be ok this summer though???? I imagine it's harder on fuel when the ecm sees a cold temp like that eh? she ran pretty good.. just once I was cruising about 60km/h and barely touching the fuel.. in od and torque converter locked I press the fuel just a little and she sputtered.. I'm at 175km's.. I'll probably do my first oil & filter change this weekend.. oil is starting to get some colour to it.. easier to see on the dip stick..
Old Feb 14, 2002 | 05:05 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Running that cold it probably never went into closed loop mode. Thus was running rich at a set BLM of 128.
tyeo098
Nov 30, 2015 06:27 PM
HoosierinWA
Oct 7, 2015 10:15 AM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
amcnellis
Sep 16, 2015 04:16 PM
