Delay wipers not working all the time
Old Feb 14, 2002 | 01:58 PM
Steve89GTA's Avatar
89 GTA
I've taken the wiper motor apart, cleaned it, re-greased gears and checked all cables and connections. When going from off the delay, the wiper motor 'clicks' but doesn not move. Low and High settings work ALL the time. If I tap the unit enough and try it again, the delay wipers work. If I tap the unit some more, they stop. Is this a common problem out there? I wanted to check the electrical board that goes to the large connector but I couldn't fish it out the plastic housing (without breaking it).
Any suggestions?
Old Feb 15, 2002 | 09:02 AM
Vader's Avatar
Steve,
Teh wiper motor delay mechanism isn't very serviceable. It can be done if you have a lot of time and patience, but it may be time to cut the bait and get a new wiper motor. Just my opinion. Then again, this is from a guy who replaced a hot wire in a MAF just to see if it could be done. DU-UH!!
Old Feb 15, 2002 | 09:05 AM
Steve89GTA's Avatar
Can it be done? I have a unit with a broken wire...want it?
Old Feb 16, 2002 | 09:45 AM
Vader's Avatar
Send the MAF core back to Tomco - they rebuild and resell them.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
slade5612
Aug 11, 2015 07:19 PM
