ignition question...
Old Feb 14, 2002 | 07:42 PM
Blade69's Avatar
how important is it to have a really good ignition setup??
Will it give you extra HP???????
Old Feb 14, 2002 | 08:33 PM
Blade69's Avatar
ANYONE?!?!?!?!?!
Old Feb 14, 2002 | 10:38 PM
Vader's Avatar
If you have a relatively stock engine with no more than 10:1 compression, a stock system in good condition is adequate to 4,500-5,000 RPM, where it will tend to fall off in spark energy. If you have higher compression pressure from alterations or boost, the spark may extinguish at a lot lower RPM.
How's that for evading a direct answer?
Old Feb 15, 2002 | 05:56 AM
Blade69's Avatar
would it be alright for a 71 350 8:1 CR?????????
thx for answering
:hail:
Old Feb 15, 2002 | 08:31 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Depends on what your "stock" system is. On the 71, I think they were still using points..... Such fun. If you go to the junkyard, you can score an HEI distributor, with vacuum advance for under 20 bucks. It is a one wire hookup. (must be hot in start and run)
Have fun.
Old Feb 15, 2002 | 08:47 AM
Vader's Avatar
Blade,
If you are running at 8:1 with no boost, no charging effect, no nitrous, and on regular gasoline (no nitromethane) the stock HEI system should be adequate to 5,000 RPM with a good coil. Since it's a '71, you may still have the Kettering (breaker point) distributor, and a CD box or conversion to HEI may be a good idea at higher RPMs.
Old Feb 15, 2002 | 02:39 PM
Blade69's Avatar
i forget to say that its been board out to 0.030 making it a 355. would this cause the CR to go up?? Iam asking this because the ignition feels real weak, before the motor use to have a load low rumble when i start it up and now you can barly here it and feels slugish.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
