350 or 305..anyone?
Old Feb 15, 2002 | 10:07 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
350 or 305..anyone?
ok...a friend of mine states that you can tell a 350 from a 305 by the dipsick.
he says the 350's have the dipstick on the passenger side, and vice-versa for the 305.
is this true?
i can't figure out which engine i have...came with a 305 stock, but was told it had an early lt1 swapped into it.
can anyone help?
Old Feb 15, 2002 | 10:19 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not true. The SBC dipstick move from driver's side to passenger side occurred around 1979 for all versions.
Old Feb 15, 2002 | 10:23 AM
sleeper's Avatar
what he said
The only way to tell if it's a 350 is to get the casting number off the block behind the drivers side cylinder head.
Old Feb 15, 2002 | 02:04 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
5-7 and sleeper are right bro.
mine is a 350 with the dipstick on the pilot side.
Fern.
Old Feb 15, 2002 | 03:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What everyone else said. When I had the 305 in, the dipstick was on the passenger side.
Old Feb 15, 2002 | 08:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by sleeper
You can also get the last 3 #'s off the side of the block just under either cyinder head.
For instance, my 350 that I am putting in my car (someday ) is a ...638. The number on the back says 5.7L . So I guess it just depends on which one you are able to see. Just letting you know so you can use either one.
AJ
Old Feb 15, 2002 | 09:04 PM
GreenProStreet's Avatar
Casting number only. They even have the same freeze plugs. Gm just wanted to be cheapskates and bore out a 305 for the truck engines through the 70s and mid 80s.
Now picking out a 305 crank in a pile of 350 cranks is extremely difficult, and the 2 cant be mixed!
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
