What to put on the top end of ARP head studs?
Old Feb 15, 2002 | 01:21 PM
Jester's Avatar
Topic says it all. I know the block-end needs thread sealer...but I've forgotten if you should use loctite or if you need to use motor oil on the top side.
Old Feb 15, 2002 | 01:25 PM
JeffT's Avatar
Car: 1991 Z28
The best thing to use would be the ARP lube but motor oil will work.
Old Feb 15, 2002 | 03:41 PM
ede's Avatar
ede
any moly based lube, ARP happens to be what i use and what jegs sells, moroso also makes it
Old Feb 15, 2002 | 03:55 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the washer should be sufficent
you arn't going to reduce the turning load much..the threads are the main point of resistance.
Frozer!!!
Jan 19, 2024 04:55 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
355tpipickup
Aug 25, 2015 12:54 AM
