Which plug is which when looking at engine
Old Feb 18, 2002 | 06:45 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
As you look at the engine from the front of the car, I want to know which the cylinders 5 and 7 are so I can make extra sure the leads don't touch.
Is #1 the first on the drivers side? Is #2 the the first on the passenger side and so on?
Appreciate the help.
Felix
Old Feb 18, 2002 | 07:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
#1 cylinder on all engines is the cylinder that is at the front of the block. On chevy engines it happens to be on the drivers side (LH side). If you look at the heads, the LH head is farther ahead than the RH head. Chev numbers their cylinders odd on the LH and even on the RH.
1-2
3-4
5-6
7-8
Most but not all engines are done in this pattern.
Old Feb 18, 2002 | 07:47 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks Stephen, so #5 & 7 are the ones nearest the firewall on the drivers side.
Old Feb 18, 2002 | 08:09 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Correct.
Old Feb 18, 2002 | 08:41 AM
Vader's Avatar
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
