Size of the breather holes on the valve covers?
Old Feb 18, 2002 | 03:43 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I would go out and measure but my car is a few miles away. Are the holes the standard 1.25 on the center-bolt valve covers?
Old Feb 18, 2002 | 07:20 PM
ede's Avatar
ede
i'd go out and measure mine for you but me and my car aren't even in the same time zones. i was thinking mine was 1", but it's been over a year since i needed to know or measured it.
Old Feb 18, 2002 | 07:37 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Can you use a breather instead of an oil cap? I was wondering cause I saw a pic of a breather in the place of where my oil cap is... but it may have just been a different model with the oil cap on the other side. I mean, it's not pressurized in the valve covers, right? So I could just use a breather instead of an oil cap theoretically right?
Old Feb 19, 2002 | 09:19 PM
Car: '89 IROC-Z
Its 1" I found an old PCV valve laying around my house and measured it.
Old Feb 19, 2002 | 09:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Putting the breather on the same side as the PVC would be defeating the purpose. I'm pretty sure you can only put the breathe ron teh side without a PVC
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
