Please explain seat pressure, shims
Old Feb 18, 2002 | 09:23 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I'm putting in an LT4 HOT (.492 lift) cam in my aluminum head L98. I know I need new springs but I'm totally clueless as to what seat pressure means. Can two different springs that are rated for the same lift have different seat pressures? Also, how do I know if I need to shim the springs?
Old Feb 19, 2002 | 02:25 AM
Guest
Guest
Posts: n/a
First, you should always use shims, or cups of some sort, since they are aluminum heads. Seat pressure is how much force the spring is exerting when the valve is closed. The manufacturer should have given you some specs for installed height, and thats what you want to have your valvetrain set at when you are done. The installed height is the distance from the spring seat to the bottom of the retainer, with the valve fully closed. This usually varies across the head due to machining tolerances and wear of existing parts. If you are really **** like me, you will check every single spring and shim appropriately to get the right installed height and same seat pressure on every valve in the head. That will take tools that you more than likely do not have though.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
wayshegoes
Aug 17, 2015 12:00 PM
