Whats needed to turn 2.73 to 3.42posi?
Old Feb 20, 2002 | 03:25 PM
Minion's Avatar
I want to install 3.42 gears with a posi unit. Are the gears and posi unit all I need? Or are there spider gears and the like that must be installed as well?
Old Feb 20, 2002 | 05:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is more than one way to do this.
1) Buy a 3-series posi carrier and a set of 3.42 gears and have them installed.
2) Buy a set of 3.42 gears for a 2-series carrier, have them installed, then put a PowerTrax conversion in.
3) Buy a complete rear with 3.42 gears and put it in your car. If it has posi, you're ready to go. If it doesn't, get a PowerTrax conversion and put it in.
#'s 1 & 2 will end up costing you about the same, as the PowerTrax and posi carrier cost about the same. The PowerTrax will click as you go around corners, so you have to decide whether if you can live with that. The big advantage of the PowerTrax is that it can be installed without any special tools, but since you want to change gear ratio as well, that probably isn't a factor for you. But, they are somewhat tougher than a clutch-type posi as well.
The spider gears you have now will not be in the picture for you when this project is complete.
Old Feb 20, 2002 | 09:26 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
of your going for cheap, i'd say go with the torsen from slp and a gm or richmond 3.42 gear.
Old Feb 20, 2002 | 09:42 PM
Minion's Avatar
Cheap is one thing, but how much power can that setup take? Same as a stock 92 Z28?
Old Feb 21, 2002 | 03:27 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd go with the SLP posi and a set of gears. I just saw gears for sale for $50 shipped on camaross.com. That'll do it.
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
