350 truck block externally or internally balanced
Old Feb 20, 2002 | 06:03 PM
Tallboy's Avatar
checked the block numbers from old book
and said was 350 roller block from truck with one piece seal
84-86?
the crank is not in it
were these internally or externally balanced?
how can i check with out the crank???]
i dont have the numbers on me now from the block
Old Feb 20, 2002 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The key is that it is a one-piece rear main seal. That means it uses a flywheel or flexplate with a weight attached, making it externally balanced.
However...
The harmonic damper is NOT an externally balanced piece for that engine! Use a normal internally balanced part on the front end.
This is a little confusing, because the 400 SBC was externally balanced on both the harmonic damper and flywheel/flexplate because of the long stroke. In 350 and smaller engines, though, the two-piece rear main seal design crank had a counterweight cast into it external to the seal. When they went to the one-piece design, they couldn't put that counterweight there anymore, so they put it on the flywheel/flexplate. The good news is that a two-piece rear main seal flywheel/flexplate will not bolt to a one-piece crank.
I'm a little suspecious of the data you have, though. The one-piece rear main seal came out in 1986. Roller lifters came out in 1987.
Old Feb 20, 2002 | 07:02 PM
Tallboy's Avatar
ill have to get the numbers again
but it did have 4 bolt mains a one piece seal
and the provisions for a spider thing that holds the roller lifters
it was sitting next to a flat tappet block so the diff was clear
Old Feb 20, 2002 | 08:22 PM
five7kid's Avatar
Sounds like an '87-later block, which means it is also one-piece.
The rear main cap and the back of the block will also look different between the two. The one-piece seal is held by a seperate aluminum holder, while the two-piece seal is held in by the rear main bearing cap & block.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
