Expert on hatch pulldown needed ... please help
Old Feb 20, 2002 | 08:20 PM
Belker's Avatar
My ('91 Camaro) power trunk pulldown is stuck in the up position. The motor makes no noises. The latch release works fine using either the key or the console button.
I tried pushing the little switch. Nothing happens by pushing this switch except that the light goes off and one of the wires that plugs into the motor goes from 0V to 12V.
What does the relay do? It has nothing to do with the latch release mechanism because it works fine even with the relay removed.
How do I know if the relay is bad?
How can I bypass the relay with a jumper wire to see if the motor works?
On the plug that connects to the motor there are 4 wires (blue, brown, orange, white ... I think). Two are constant 12V. One is 0V except when the switch by the latch is pushed then it is 12V. I don't really know what the other wire it does (exept that I didn't measure a voltage change on it).
The fuse is good. The wires look to be in good condition. The grounds seem good. Nothing looks to be physically damaged or broken. Everything worked fine earlier today.
Can anybody help me out? Any insight on how I can get this fixed?
Old Feb 20, 2002 | 08:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What's the purpose of the hatch motor going down? besides it not locking the hatch
Old Feb 20, 2002 | 08:43 PM
Belker's Avatar
It pulls the hatch from a almost closed position to a closed position. As far as I know all later model third-gens came with this pulldown mechanism. I guess it is to prevent damage caused by slamming the hatch closed.
Old Feb 20, 2002 | 09:01 PM
Snowdog 91 Formula's Avatar
Motor in Hatch
Well, what I did on my wife's car was take off the motor and all mounts to it...
My friend took out his welder and tack welded the latch to the rail. Took 2 tries.
Be sure to cover your carpet so it won't get burned.
Old Feb 21, 2002 | 06:46 PM
Belker's Avatar
I tried a new relay and it didn't help.
Old Feb 21, 2002 | 07:02 PM
AlexJH's Avatar
Engine: 5.7L V8
Belker, I had the same problem. My motor thought it was in the down position already so it wouldn't close any more.
What I did was take the 12v source from the trunk light and apply it to the wire that wasn't doing anything (I think this is the one, but you'll probably want to get a wiring diagram to check). I let it run all the way down, then closed the hatch. After that, it knew where it was again, and I haven't had any problems.
Old Feb 22, 2002 | 02:04 AM
Belker's Avatar
I decided to pull the whole assembly from the car, tore it apart into at least 100 pieces, and then put it all back together. Now it works. Yipee!
I don't know exactly what was wrong but I did find the switch that tells the motor when to go up or when to go down. It's on the small black box that is attached to the top of the clear plastic housing for the gears. Flipping that switch may have solved the problem.
Old Feb 22, 2002 | 06:32 AM
KeithO's Avatar
There is an old thread on this that had pictures on what to try before you go crazy with extra work and $. That old thread "fixed" my problem. My hatch really wouldn't cose correct. On the latch motor mechanism, there is a lever that I simply fiddled and the motor began to move. The next time I closed the hatch - Viola - everything was OK and has been ever since. This thread should be from the September-October-November timeframe - do a search and you will find it.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
