Cutting braided fuel line?
Old Feb 21, 2002 | 03:27 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Is there a special tool or something for cutting braided fuel line? I keep fraying this stuff whenever I try to cut it... Are there "special" snips for it? Mine just seem to bend it (no, I'm not weak :-P)
Old Feb 21, 2002 | 03:31 PM
SoCo80p's Avatar
best cut is with a band saw, i took my line to the machine shop for the hell of it and they make a PERFECT cut,..but at home dont even bother with a hacksaw, it frays the **** out of the line, i used a cut off air tool and that makes pretty nice cuts.
Old Feb 21, 2002 | 03:47 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
you can use a hack saw.. there are a couple of tricks
tape the hose with some duct tape. Then put 2 blades in the hacksaw (one with the teeth forward and one with the teeth back) and put it in a vice. Get to it.
Old Feb 21, 2002 | 04:53 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
a vice, a few layers of TIGHT duct-tape and a fine-toothed hacksaw always works best for me. It takes a few mess-ups but after awhile you'll be doing it near-perfect. Just cut really hard and fast and don't stop.
Old Feb 21, 2002 | 05:25 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I used a dremel with a reinforced cutting wheel once, and the other time I put a pencil in it (so it wouldn't collapse) and used a pair of shears. The cutting wheel works a lot better.
Old Feb 21, 2002 | 05:39 PM
mcconahay37's Avatar
LOL. I bet.
Old Feb 21, 2002 | 07:23 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
The pencil/shear idea was one of those, "I need the car tomorrow, the fuel line leaks and it's 3am. Hey, there's some gardening shears..."
I'm so glad we have 4 cars here now.
Old Feb 21, 2002 | 07:37 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I used a die grinder with a 4" cutting wheel.
Old Feb 21, 2002 | 08:48 PM
BlackBird305's Avatar
i agree w/JCB....try the haksaw w/2 blades goin in opposite directions...seems to work well w/out fraying...i believe this tip was even given on HotRod TV one day...good luck
Old Feb 21, 2002 | 10:18 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
2 blades? I don't see how that would work being that they cut in different lines? They won't be cutting the same line but rather parallel, no? Anyway I'll have to stop at Home Depot tomorrow to check for the blades that'll cut steel, already ruined a "metal" cutting blade trying to do this and managed to fray it up real good, I never thought of using 2 blades... Thanks for the help. Any brands you guys recommend or anything?
Old Feb 21, 2002 | 10:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The hacksaw doesn't cause fraying if you use a new sharp blade with very fine teeth.
Old Feb 22, 2002 | 04:42 AM
ede's Avatar
ede
i use duct tape on the line like everyone else and a chop saw
Old Feb 22, 2002 | 10:37 AM
a73camaro's Avatar
Tried a hack saw, it was a bear to do and looked awful. Then I used a chop saw with a metal cutting blade. It was like a hot knife thru butta'.
I WILL NEVER CUT STEEL BRAIDED LINE WITH A HACK SAW AGAIN!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
