ignition guru's/need help please
Old Feb 23, 2002 | 05:42 PM
jester111's Avatar
hey guys
I think Im having a brain f@rt!
In the DIS waste spark system the coilpack fires both plugs at the same time, one is positive ground and the other is negative groung, then when that coil pack fires again it is reveresed. Can anyone please explain what is meant by that?
one more ?, if electricity flows negative to positive then would the secondary side of the coil be concidered negative and the plug electrode be concidered positive?
thanks in advanve for any thoughts
Old Feb 24, 2002 | 10:35 AM
Vader's Avatar
Jester,
If you've ever studied electricity or electronics, you'll remember Lenz's Law regarding inductance. An expanding magnetic field tends to induce a like field (and current) in a parallel winding, and a collapsing magnetic field tends to induce an opposing field (and current) in a parallel winding. For this reason, a common automotive ignition coil actually produces a high NEGATIVE voltage at the coil secondary (high voltage) terminal. The spark current at the plug travels from the center electrode to the ground (side) electrode, since conventional current flow is from negative to positive as you pointed out. This applies whether the system uses breaker point, electronic primary switching (like HEI) or a magneto.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
Ranbo108
Sep 9, 2015 12:20 PM
