WOT Low Shift RPMs'
Old Feb 24, 2002 | 04:35 AM
JR4444's Avatar
WOT Low Shift RPMs'
At WOT my car only shifts at like 4000 RPMS. I know it's not the tach because my friend's stock 350 beat me Could it be the TPS? Any ideas or suggestions? Thanks
Old Feb 24, 2002 | 05:08 AM
Blackened's Avatar
That could very possibly be a misadjusted TV cable. If that's not it get a governer that will let you shift higher. Something like 6000 RPM. Why dont you try to shift it yourself when you race ? Hold it in 1, 2, D and OD manually until 5500-6000 RPM.
Old Feb 24, 2002 | 09:31 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
try the tranny board then maybe trasnfixleo & pro-built can help you out for sure. does it do it in OD shft @ 4000? my car sometimes would shift a 3500 @ WOT in OD. if i use D it will always shift @ 5500 WOT. this was with properly adjusted TV cable,
Old Feb 24, 2002 | 10:38 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Either of these 2 will be your problem.
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
