Looking for a good set of lifters, please help
Old Feb 23, 2002 | 11:09 PM
91Firecrow305TBI's Avatar
Hi, Evidently the a lifter or a few have gone bad on my girlfriend's 383 TPI T/A. I am looking to get a set of durable lifters, better than stock to handle a pretty healthy cam (Don't have specs)
Thanks,
Clint
Old Feb 24, 2002 | 12:28 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
specs on them springs too-before cash is spent-how hungry for lifters is it? -check for coil bind or guide/retainer/keeper interference as a precaution. is the cam goin flat?
Old Feb 24, 2002 | 09:50 AM
ede's Avatar
ede
most people don't make thier own lifters so who ever you get them from most likely will be the same part.
Old Feb 24, 2002 | 06:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
When you buy the cam, get the lifters in a kit with it. It's cheaper that way.
Don't put new lifters on an old cam. That will almost certainly wipe them both out. Even if it doesn't, you'll need new ones when you put a new cam in. Do it all at once.
Old Feb 25, 2002 | 06:21 AM
Thanks for the replies
I have learned a lot. I tried adjusting the rocker arms, and that solved the problem. Thanks for all of the information.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Navy8125
Aug 22, 2015 07:13 PM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
