Oil Cooler Lines Rusting. Worth it to replace?
Old Feb 24, 2002 | 09:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My lines on my factory oil cooler are rusting. I have no clue y. Never been in snow and barely in rain. anywasy is it replacing them or ditching the crappy system?
Old Feb 25, 2002 | 07:05 AM
Hellraiser's Avatar
Re: Oil Cooler Lines Rusting. Worth it to replace?
I took the oil cooler off of my Formula, for the same reason. My lines were rotted badly from years of salt and snow. Five minutes with a cutoff wheel and 6" of rubber hose later the problem was solved. But, in order to remove the cooler itself (which you must if you disconect the coolant lines) and reinstall the oil filter you'll need new bolts for the filter adapter. The filter won't spin on with the old ones in place, they are too tall.
Hellraiser
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
