Can someone put this combo in DD2000 ?
Old Feb 24, 2002 | 05:03 AM
Blackened's Avatar
I would very much like to know how much power this setup puts out and what the torque curve would look like.
408 cid SBC
23 Degree TFS heads
Crower Cam
Adv duration 311/316 Lift 507/524
Lobe sep. 112 Duration at .050 244/252
1 5/8 Hooker headers
Edelbrock RPM intake and carb
T5 tranny
If anymore info is needed please let me know. Thanx :hail:
Old Feb 24, 2002 | 05:34 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Peak hp = 386 hp @ 5000 rpm at the flywheel
Peak torque = 435 pound feet @ 4000 rpm at the flywheel
Torque curve is very nice, over 400 pound feet from 2000 rpm on through 5000 rpm.
HP rises linearly from 155 @ 2000 rpm to 386 @ 5000 rpm (45 degree angle on the graph!) and then flattens out to 5500 before falling off rapidly.
This will make a fast 3rd gen, even with highway gears
Old Feb 24, 2002 | 01:48 PM
rezinn's Avatar
You can't accurately use DD2000 unless you also have bore, stroke, head flow specs, valve sizes, compression ratio, induction flow, manifold type, and valve timing events for the camshaft. Sitting bull did what he could with what you gave, but it probably isn't all that accurate. The curves will look similar, but the peaks will not be correct.
Old Feb 24, 2002 | 02:36 PM
Blackened's Avatar
386 HP sounds dissapointing. These heads made 419 on a 355 on some of CHP's test with a smaller cam. Hmmm... odd.
Old Feb 24, 2002 | 06:43 PM
Engine: 305-4v
I used the flow numbers file for the 23 degree Trick Flow heads and used 2.02-1.6 valve sizes. I used a 9:5-1 compression ratio, dual plane intake and 700 cfm carb. I could only use the lift and Hot Street settings for the camshaft (I have dozens of cam files but none for Crower). Nevertheless, this should be within about 20 hp.
Old Feb 24, 2002 | 07:47 PM
Blackened's Avatar
Desktop Dyno also says the Edelbrock RPM package which is supposed to make 420 horsepower on a 350... only makes a 364. So I dont know.. it seems iffy.
Old Feb 25, 2002 | 04:11 AM
Engine: 305-4v
Well, at least we can say that your 408 is going to move your Camaro very rapidly. With that kind of torque and such a quick rising hp graph, you won't be at the end of very many lines
Old Feb 25, 2002 | 05:00 AM
Blackened's Avatar
I was afraid the cam I picked was too big, even though it's listed in the Crower catalog as a 400cid camshaft. Well hopefully it'll be fun with a 5 speed behind it. And of course I will have to pray to the torque gods every day, so they wont unleash their powers on my poor T5 !:hail: :sillylol:
Old Feb 25, 2002 | 05:14 AM
Engine: 305-4v
Hmm, a T5 might not last very long behind that thing. A Tremec sounds more suitable, but the price of admission is nasty.
Old Feb 25, 2002 | 05:35 AM
Blackened's Avatar
Very much so. It lasted behind my 400 HP 350 for a while. I dont powershift and dump clutches so I think it'll be alright. (for a while anyway).
customblackbird
Aug 15, 2021 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
