Vortec bench flow data?
Old Feb 26, 2002 | 03:13 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Can anyone post some numbers for the L31's bench flow data. I know it was in one of the recent Car Crafts, but I can't find it anywhere. Thanks for the help.
Old Feb 26, 2002 | 03:29 PM
GreenProStreet's Avatar
www.chevyhiperformance.com
They gloat that they have all the flow data for every aftermarket chevy head, but they dont have the numbers on Fast Burns ! But I am sure they have it on the Vortechs.
Old Feb 26, 2002 | 10:03 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Thanks, that's an even better article then I was talking about in Car Craft. Next time somebody wants knock Vortecs, I'll just send them there.
Old Feb 27, 2002 | 03:48 PM
Np.
It isnt a bad sight, eh? The format can be a bit confusing, and **** you off, but all and all some good info.
Old Feb 27, 2002 | 05:51 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Flow numbers aren't everything.... The Vortecs require other parts to deploy them on most engines and upgrades to the valvetrain are a must to run any appreciable lift with them, which makes them less desirable depending on the end goals for the engine. I agree that they may be the best bang for the buck out there, but only by a little bit - and not if your plans include making really big power in the future or are looking for the benefits of an AL head.....
Laterzzzzz,
Matt
Old Feb 27, 2002 | 06:24 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Matt,
I'm not trying to flame here, but most people using Vortecs use them for a budget engine. I used them b/c they came on 1 of 2 350's I bought for $500. You are correct in the parts needed for use. They do require a specific intake, self guided rockers, and are only compatible with centerbolt covers, unless a $130 adapter is used. Bottom line for me is they are good heads, but there are better aluminum, and even aftermarket iron heads out there. If your on a budget, I would recommend them. If you aren't, and are looking for over 375hp, look harder at some others.
Old Feb 27, 2002 | 07:05 PM
Laterzzzzz,
Matt
True, true.
$200-300 for a 375 horse head aint bad. The true benefit of these heads are their 90s technology. The quench factor is the best of any iron head and let you run alluminum compression ratios, without much fear of detonation. And it is a nice, crisp, fuel efficient burn, secont only to fast burn heads. Both are based upon technology inspired by the Ls1 head.
Cant beat that for $250!!!
Old Feb 27, 2002 | 08:38 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
hmmm
I wonder how the fastburns compare to the vortecs? definatly a sizable weight savings...
I'm wondering if a fastburn swap from the vortecs would give you a appreciable hp gain? changing nothing but the heads..
Old Feb 27, 2002 | 08:58 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: hmmm
Hey, you are using Apeiron's avatar! He won't like that.
Vortec's are good for more like 450 hp. Chevy High Performance just did a 422 hp engine with them late last year.
Old Feb 27, 2002 | 11:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by GreenProStreet
True, true.
And don't forget the swirl capabilities. That's what makes them so great. Just from that alone actually makes them happier with less advanced ignition timing. They're very efficient.
BTW, IIRC, they're based on the LT1 design.
AJ
Old Feb 28, 2002 | 10:59 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Re: Re: hmmm
Who's Apeiron?
btw I got this off an avatar site. :rockon:
Old Feb 28, 2002 | 11:46 AM
Engine: 305-4v
Re: Re: Re: hmmm
Who's Apeiron?
He's a regular on this site. He's used that avatar since they've allowed them.
Old Feb 28, 2002 | 01:18 PM
Jester's Avatar
As I recall Aperion drew and animated that himself too.
Old Feb 28, 2002 | 05:36 PM
johnsjj2's Avatar
Car: 1991 Z-28
Sitting Bull,
Your right. I have seen a couple build ups, both going over 400hp. I was just thinking that if someone wanted 450hp, they probably have the money for higher end heads.
Old Feb 28, 2002 | 06:08 PM
AJ
I know someone would give me grief (not much) for that when I said that. It was inspired by the LT1, but the LS1 and Ls6 use the same technology.
Swirl? I prefer quench, and that is what I meant about the 90s technology. For you amateur engine builders, just because you dont have 90 heads, doesnt mean you should give up on quench.
Old Feb 28, 2002 | 06:11 PM
Originally posted by johnsjj2
Sitting Bull,
Not nessesarily. If you can get away with Iron heads, than spend the saved money somewhere else. Put porting these heads for 450+ hp flow numbers would add up to alluminum head prices quickly.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
