Ok place to bolt ground cable strap? Coil Bracket?
Old Mar 2, 2002 | 03:59 PM
Night Hawk's Avatar
Hey I got a quick yes or no question.
You know the ground strap that comes off the firewall and bolts on to the engine block?
I can't reach or even see where it bolts to the block, but I see that I can bolt the strap to the metal bracket that holds the external ignition coil. Is this an ok spot to bolt the strap too? It seems like a fair size metal bracket.
Old Mar 2, 2002 | 04:21 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I wouldn't put it there.
I believe it bolts to the back of the cylinder head. There should be a stud threaded into the head. It should have a ground going to it already. Undo the nut and put your strap over the stud, then put the nut back on. If you don't have the grounds on the head, look in the wiring harness to find them. There should be at least one on either cylinder head. Good luck.
Mike
Old Mar 2, 2002 | 05:10 PM
sleeper's Avatar
If you can't find the stud in the head then it must have been removed. A hex bolt with some locktight would be a suitable replacement.
I wouldn't bolt it to the coil... it could cause electrical interference.
Old Mar 2, 2002 | 07:52 PM
rezinn's Avatar
The ground strap connects to both the firewall and the block. You should connect the large ground to the bottom of your accessories or something touching the block, if not the block itself. You needn't run it all the way to the back of the head, but if you want to that would work.
Old Mar 2, 2002 | 11:46 PM
onebinky's Avatar
on my 85 z28 it was between the bellhousing and the block on the top passenger side bolt.
matt
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
9192camaro
16
Feb 3, 2019 12:21 AM
