Need some advice on fixing a little problem.
Old Mar 2, 2002 | 07:30 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I have got my base intake manifold off, and I been porting out the runner openings and matching them to new gaskets. But tonight I slipped a little with my Dremel tool, and made a little slice across the gasket surface. It goes across the flat surface between 2 runner openings, towards the center of the intake bottom. It is not real deep, but went completely across from the runner opening to the other side. I think it would cause a leak, even if you got the gasket down good.
How should I fix this? J-B Weld and smooth it out flat? Or maybe just use some copper high-tack gasket sealer to fill in the crack? I wasn't planning on putting high-tack around the runner ports, just maybe the coolant passages.
TIA!!
Old Mar 2, 2002 | 07:37 PM
rezinn's Avatar
I don't think jbweld has the correct properties to work well on this application. The best solution would probably be to mill the intake a small amount on each side.. just a little would maintain the correct port locations, but I don't see why the sealer/silicone wouldn't work. If it doesn't, it isn't a big deal to pull the intake once more and have some work done to it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
tgp1990
Sep 4, 2015 06:24 AM
mrdevontay
Sep 2, 2015 08:04 PM
