How Can I tell if I have a 350?
Old Mar 2, 2002 | 11:12 PM
84CamroHO's Avatar
I can't tell if my camaro is a 305 of a 350. I have had two mechanics look at it, one said it was a 305 and the other said it was a 350. I dunno which one is right. Does anyone have any ways to tell if it is a 350 or a 305? Also where can I locate the bock casting numbers?
Thanks For all the help
Old Mar 2, 2002 | 11:21 PM
Blackened's Avatar
Look at the back of the block to the driver's side of the distributor. You'll see a number, a big "GM" logo and usually a 5.0L or a 5.7L. If you only see the number, get the number and go to www.mortec.com to look it up.
Old Mar 2, 2002 | 11:23 PM
ChevyLuva3's Avatar
Just punch in your VIN number in the VIN decoder. Its on the main page of the thirdgen site.
Old Mar 2, 2002 | 11:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What ChevyLuva said if the motor is original, if it's not check the # on the block. If your car is a stock HO, it's a 305. And I'm not sure but I don't think 350s were available after I would say 82-83, but don't quote m on that and didn't return until I know in '87.
Old Mar 2, 2002 | 11:41 PM
Blackened's Avatar
350's were available STARTING in 87. Some people will tell you they have an 86 with a 350. Those were very rare, if they even exist.
Old Mar 3, 2002 | 02:42 AM
ronterry's Avatar
Car: '94 Corvette
Don't forget the obvious... A 350 will have a 4 inch bore, and a 305 a 3.74 inch bore.
That's of course if you have the block on a stand
Ron
Old Mar 3, 2002 | 05:23 AM
Blackened's Avatar
LOL... well YEAH! Although it something tells me he's not gonna take the heads off just to find out if he has a 350 or not. LOL
Old Mar 3, 2002 | 11:37 AM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
............Not sure about that.......punch my vin # in, and you'll get 305. Look at my casting #'s on the block and sig, you'll see something different.
Old Mar 4, 2002 | 10:08 AM
Snowdog 91 Formula's Avatar
My L03 died
My L03 died and I replaced it with a 708520 HD engine from Recon. 3/36,000 Warranty. Talked to the mechanic as it was being built. With the performance line of Recon engines, they assign one ASE mechanic to build your engine and it takes a couple weeks to build.
I have the paperwork for it somewhere in this place, but I was wondering if I should put that information in with the car if I ever (which will be never LOL) decide to sell my car?
It was not a simple project, and I'm happy I did it. After installing the motor, the Wolverine cam was wayyyyy too much for it, so I dropped in a Crane 2030 and have been happy ever since.
I'm just wondering should I put the paperwork on the motor with the car paperwork for future reference?
Old Mar 4, 2002 | 04:41 PM
Blackened's Avatar
FOR SURE ! IF the engine ever craps out on you... you'll need those for warranty info.
Old Mar 5, 2002 | 03:35 PM
Omar's Avatar
Which is exactly why you dont use VIN's to figure these things out. If you are not the original owner, and you do not know the history of the car, you will find that people swap out engines all the time. That little tag on your rear diff could be misleading too. It's easier to look at the casting number, and for other things, count teeth.
Old Mar 6, 2002 | 12:30 AM
simon's Avatar
Been there done that. As a general rule of thumb: If you have to ask, then its a 305.
Old Mar 6, 2002 | 07:34 AM
Z28DJP1987's Avatar
I have to agree with Simon on his comments.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
