Temp Gauge Problem
Old Mar 3, 2002 | 08:26 PM
kidcamarosc's Avatar
Temp Gauge Problem
Im having a problem with my temp gauge not working. When i start the car up it moves all the way to 260 or whatever but falls back down to 100 and doesn't move while driving the car. any help apreciated thanks
__________________________________________________
88 Camaro SC
Black w/ Gold GFX and Rims
160000 miles and still rollin
305 TBI w/ open KN
Hooker Cat Back
Old Mar 3, 2002 | 09:14 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
It could be that you need a new coolant temp sensor that is near the water neck. Or its not connected, might be a coolant switch instead of a sending unit,or frayed wires, or a bad gauge.
Old Mar 4, 2002 | 08:32 AM
Vader's Avatar
Re: Temp Gauge Problem
ALL GM cars will "peg" the temperature gauge on cranking, then return to the correct reading once the engine is running.
If you temperature gauge never reads above 100°F, you may have a problem with the gauge sending unit or an overcooling problem, such as a stuck open thermostat. Verify the coolant temperature with a thermometer in the radiator (cap removed). If the temperature gauge is not reading correctly, the first step would be to check the temperature sending unit. Of course, teh coolant level is correct, right?
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
