why cant i stall...?
Old Mar 3, 2002 | 09:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ok i just had 3.73 posi setup in my rearend and before with the peg leg 2.73 i could stall to about 1250 RPMS now with the new gears/posi i can only stall to about 1300 RPMs with the same tire pressure. is this because i removed my rear anti-sway bar? it is off becaust i broke a bolt holding it on. i thought i would be able to stall a lil higher with a posi. whats up with this?
Old Mar 3, 2002 | 10:13 PM
Blackened's Avatar
Gears and posi dont affect stall speed ! ! Your torque converter does !
Old Mar 3, 2002 | 10:19 PM
ronterry's Avatar
Car: '94 Corvette
Torque at the engine also has an effect on stall, but not as much as say going from a 1500 stall convertor to a 3000.
Ron
Old Mar 3, 2002 | 10:29 PM
Blackened's Avatar
And what does THAT have to do with the rear end gears ? LOL Is this like your other reply to my post where you said I missed the obvious difference between a 305 and 350... the bore size ! DOH... not when you're looking at a complete running engine in a car ! LOL
Old Mar 4, 2002 | 01:11 AM
ronterry's Avatar
Car: '94 Corvette
sorry, the removing of the sway bar threw me off
Hey, 'brodyscamaro' the difference of 50RPM's might be do to varying trannie oil temps.
Ron
GTA Sammy
Jul 21, 2014 07:15 AM
-AO-
South East Region
Oct 31, 2012 07:38 PM
88fastgta
Mar 19, 2012 01:18 PM
scarr001
Sep 28, 2011 05:50 PM
bobbyk3lly
May 21, 2011 09:14 AM
