vortec FIRST tpi
Old Mar 18, 2012 | 07:11 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
vortec FIRST tpi
hey guys i have interest in switching my baseplate over to a vortec style FIRST intake and run vortec heads...... would this be an improvement over the standard FIRST running iron l98 heads..... i just dont want to spend 1700 dollars on afr heads after getting them milled down to 60cc and accessory holes drilled and tapped for it... i just want to achieve 355whp and i think that vortec heads can get me there without the crazy expense of afr priced heads...
what do you guys think...... how does this combo sound
355 block
vortec heads modded to take .550 lift
gm hotcam
vortec FIRST TPI
vigilante 2800 stall...
Old Mar 19, 2012 | 10:19 AM
88fastgta's Avatar
Re: vortec FIRST tpi
was thinking about running these... im not sure if they are any different than standard heads other than the size of the cc and being able to take .520 lift..
http://www.summitracing.com/parts/SUM-151124/
also it doesnt say if it has screwed in or pressed in studs...
Old Mar 19, 2012 | 10:59 AM
88fastgta's Avatar
ok i did my research and come to find out they flow less than standard gm vortecs... so im scraping the vortec idea....
Old Mar 19, 2012 | 01:18 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You can get AFRs for less than what you posted. The 195s would suit your 355 needs.
Question? Did you knock down that bulge in the intake track on your First where the injector is? That is way larger than it needs to be. If it was mine I would grind it all the way but make sure there is enough material for the injector o-ring to seal.
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
Sanjay
Aug 12, 2015 03:41 PM
