Heads
Old Mar 4, 2002 | 06:46 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Heads
Unless your running rocker arm girldle there should be no reason to run tall valve covers. Maybe I read your post wrong but I don't have tall covers and they fit fine as for the longer pushrods, either the 23* or the G2 you have to run longer pushrod on one side I forgot which one, call 1-800-630-1555 that is trick flows tech line they will know. I didn't have to run longer ones with mine becuase I have the older style twisted wedge heads. As for the cam question, it depends on alot of different things. What fuel system you running, carb or TPI?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
