350 build up - your comments please
Old Mar 4, 2002 | 11:01 PM
84 Bird's Avatar
Hi,
I am building a 350 for my 84 Firebird. Here is my plan
350 block +.030
speedpro forged pistons 9.?? comp ratio
stock 70cc heads valve and port job
performer rpm intake
750 carb
headers
high flow cat.
700r4 trans
stock gears ??
what would be the best cam for this setup? I would really like to hit the 13's.
Thanks for any tips.
Old Mar 4, 2002 | 11:39 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: 350 build up - your comments please
Originally posted by 84 Bird
Hi,
350 block +.030
750 carb
headers
high flow cat.
700r4 trans
stock gears ??
Comp Cams xe268 or xe274 with 2000/ 2600 stall. Emissions?
Blackened's Avatar
Try a cam with something like 220/230 duration and around .500 lift. The Edelbrock RPM cam comes to mind...
Old Mar 4, 2002 | 11:44 PM
84 Bird's Avatar
No Emissions.
Old Mar 5, 2002 | 12:22 AM
darbleinad's Avatar
Car: 84 Trans Am
as for rear end gears, you didnt say what you stock gears were, but you will want to get some fairly low gears (higher numerically) to get good quarter mile times...for example 3.73s. My 84 TA has a stock rear end with 3.23s...i am hoping to swap in some 3.73s to improve my off the line performance
good luck with the build up
Old Mar 5, 2002 | 05:48 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
No Emissions.
Same reply as before, then.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
sreZ28
Aug 14, 2015 07:48 PM
