350 corvette engine in Trans Am GTA
Old Mar 5, 2002 | 01:45 AM
highway22002's Avatar
Hi!
It looks like I have a '89 350 corvette engine in my '89 Trans Am GTA. So the question: what should be compression ratio
for this engine? Now it is about 10. Is it good?
thanks,
Marcin
Old Mar 5, 2002 | 07:47 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
welcome to the boards,
stock i think those engines were about 9.5:1. The corvette aluminum heads are 58cc as opposed to the f-body ones which are 64cc. F-bodies have a compression of 9.3:1 with the 64cc heads. The corvettes only have a slightly higher stock compression because they used a thicker head gasket than the f-bodies at the factory to lower it. You probably have standard thickness head gaskets now and that's why it's 10:1.
This is exactly how my engine is being built, with the standard gaskets. You probably should be using high octane gas like 91 or 93.
Old Mar 5, 2002 | 08:26 AM
Thanks for help.
So its all ok, I suppose
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
