1.6rr on ZZ4 motor?
Old Mar 5, 2002 | 11:52 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
1.6rr on ZZ4 motor?
I got a ZZ4 motor and wanted to run 1.6 pro magnum rockers. The motor has LT4 springs. Anyone else running these?
Old Mar 5, 2002 | 01:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have a bud w/ZZ3 (basically the same as ZZ4), ZZ9 cam, 1.6 rollers (don't think they're Magnums, though). Not sure what springs he's using, but I doubt they're what came on the engine.
I do know he said the rockers fit w/o interference to the covers w/o modification. Other than than, I'm not sure what his setup experience does to help you know what you want to know.
Old Mar 5, 2002 | 06:36 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
GM sells the LT4 hot cam and 1.6rr as an upgrade to the ZZ4. So I would guess the stock springs would be fine.
Old Mar 5, 2002 | 08:02 PM
Blackened's Avatar
Well NO that won't work. The ZZ4 cam has a lift of .510 on the exhaust. That would mean .544 with 1.6 rockers. I REALLY doubt the stock springs will handle that. The LT4 HOT Cam only lifts up to .525 with 1.6 rockers. Get some better springs, then you can put 1.6 rockers on it ! Or better yet, get the LT4 HOT cam and make more power too.
Old Mar 5, 2002 | 08:25 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
What kind of springs would you recommend? Do you have an approximate price?
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
