Opinion on spark plugs and wires?
Old Mar 5, 2002 | 11:11 PM
Druo-Z28's Avatar
Whats a good brand of spark plugs and wires for my car? 350 tpi?
Old Mar 5, 2002 | 11:13 PM
Blackened's Avatar
Accel's 8mm black wires. (Pro stock version) and regular AC Delco plugs !
Old Mar 5, 2002 | 11:18 PM
Druo-Z28's Avatar
what about msd wires? bosch platnum spark plugs? or the quad fire ones?
Old Mar 6, 2002 | 12:07 AM
Druo-Z28's Avatar
Also are the SpitFire3 platinum spark plugs or the NGK plugs good? just looking for a few opinions
Old Mar 6, 2002 | 12:49 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Stay away from bosch and splitfires they are gimmic plugs. I used both of them for extended periods and bosch even used one of my ideas to improve the +4s (well Im sure anyone could have thought of it)
the +4s actually have more electrode area to get in the way of flame propogation than a standard spark plug so when mine started running bad I clipped two of the electrodes and they actually ran better until one of the insulators (around the center electrode!) broke and I chukked them. witness bosch's new design the +2s (ha!)
stick with delcos.
Old Mar 6, 2002 | 01:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just go with the AC delco plugs. For the wires I'd get the MSD SuperConductor one's. I here they are very good.
Old Mar 6, 2002 | 06:10 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i use accel shortys for header clearance and msd 8.5 mm wires...what ever you do dont buy splitfire plugs they are crappola......
Old Mar 6, 2002 | 07:16 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I used them for a long time and they have the lowest resistance of any aftermarket wire (tested by shops). I do like others better though because the splitfires are a little thin.
Old Mar 7, 2002 | 02:31 PM
86iroctpi's Avatar
Car: 86 IROC
If you ever plan to put headers on that thing, I suggest that you go with a set of Accel Super Stock Universal Fit wires and make them a little longer. Stock length wires won't give you enough length to keep them away from the headers. I also agree that splitfires suck!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
