OVer heat fixed Thanx!!
Old Mar 6, 2002 | 10:00 AM
David Petersen's Avatar
Well I posted last week about an overheating problem, and just thought I would post the outcome. The car was running hot when you drove it but not at idle. It would boil after about 8 blocks of driving. At first we thought it was missing the coil spring in the lower radiator hose until after contating the dealer they said the lower hose never had a coil in it??? But the shop opened the cap and saw tons of bubbles!!! Turns out the geniuses at the parts store sold me the wrong water pump wich was running backwards for the old style V belt sytems. So we got an AC Delco (ouch $$$) water pump to be sure and she doesn't even get to 220* now. I think Kregan ows me $270.00!!! Plus my $30 back for the crap pump!!!
Old Mar 6, 2002 | 11:54 AM
Vader's Avatar
DP,
Thanks for the update on the outcome. It's always good to hear how something works out. You really have to watch the pump rotation. Either pump will move at least a LITTLE coolant in either direction, but not enough to cool effectively.
This rotation difference, and the chance of getting an erroded or undersized impeller on a remanufactured pump is another good reason to remove the pump inspection cover before installing any replacement pump. They're all the same on the outside.
Old Mar 6, 2002 | 07:49 PM
Blackened's Avatar
You paid 270 dollars for a frikin stock water pump ?? Please tell me you're joking!
Old Mar 6, 2002 | 08:02 PM
farm-kid/88camaro's Avatar
im running my stock pump on a vortec motor. Is this pumping in the correct direction? I've been having some problems overheating, so just wondering
The cars an 88 with the serpentine system, originally had a 305tbi
thanks
Old Mar 7, 2002 | 09:25 AM
I belive it should be correct as long as you are using the same pully system as with the origianl motor.
Old Mar 7, 2002 | 09:28 AM
And I only paid $109 (still a lot) for the water pump the rest was labor, coolant, thermostat etc.
92firebirdguy
Sep 1, 2016 07:53 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Stryker412
Sep 20, 2015 06:59 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
