Engine misses on startup after A/C has been on
Old Mar 7, 2002 | 04:15 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I'm getting my car back out of storage in a couple of weeks, and I just remembered a problem I was having with it. In the summer heat, after running the air conditioner, shutting the car off to go into the store or something, and coming back out and starting it, it is hard to start, as it does not want to idle, and for the first few minutes of operation, even misses while you're going down the road. The interesting thing is, if I turn the air coditioner off (usually works better if I do this a few seconds before shutting the car off), it doesn't do this when I go to start the car again. Is there a vacuum problem? Am I getting vapor locked? Is the computer messed up? Or, could it just be a problem with the selenoid mounted on the side of the carb that turns on when the A/C cycles. Has anybody else had this problem?
Oh yeah, the motor is an LG4 with factory everything, for now.
Old Mar 7, 2002 | 05:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is caused by the fuel in the fuel pump getting hot and boiling... the fuel in the pressurized oart of the line is OK until it passes through the needle valve into the carb, at which point it violently boils, which makes fuel spew out the top of the carb and into the intake. It's the opposite of vapor lock, which is the fuel in the line before the pump boiling, so the pump pumps only evaporated fuel which is of course not dense enough for the car to run. Usually the car will run like dog plop for the first 30 seconds or a minute, blow out black smoke, miss, and otherwise run awful until some fuel cooler than the boiling point makes its way to the carb. Adding an extra gasket between the pump and the block, or using a phenolic spacer, will help.
Old Mar 7, 2002 | 06:05 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks, that makes perfect sense, but why doesn't the car do it in the same heat of summer if I don't have the air conditioner on? You are right though--it runs like sh#t for about a minute or so, and then it's fine.
Old Mar 7, 2002 | 06:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Extra heat blowing on the fuel pump from the A/C condenser... the engine coolant might not be very much warmer, but the underhood temps are as much as 50° higher with the air on
Old Mar 7, 2002 | 10:23 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Sweet man, thanks. Even if there's not much I can do about it, at least I know that this is normal.
Old Mar 8, 2002 | 02:27 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
GM had a bulletin posted on this problem. I found out from the dealer since I had the exact same problem you're having. Basically, GM has no good answers on how to fix the problem. I bought a 1" phonelic resin spacer from jegs and it solved the problem almost completely (and gave me a few extra horses to boot!).
Old Mar 8, 2002 | 03:46 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
That sounds like a great plan, but how did you make the pushrod that drives the pump work? Did you get a longer one? Also, did longer bolts come with the spacer? How much was the spacer, and do you know the part #?
Old Mar 9, 2002 | 02:30 AM
What pushrod and what pump? I just bolted it between the carb and the manifold. Dont know the p/n number, but its in Jegs and the spacer is made by Berry Grant. Was like $50. I bought longer bolts from Ace Hardware. Just bring the stock bolts and get ones an inch longer.
Old Mar 9, 2002 | 09:07 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
My bad, I thought you were talking about the fuel pump, thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BikeFarm
Aug 11, 2015 11:35 PM
