Anyone know how to vert PSI to compression ratio?
Old Mar 7, 2002 | 10:23 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Ok, just dropped in my .040 over 350 and haven't taken it for a ride yet, but I just checked my compression on one cylinder and got 185 psi. I was expecting pretty high, but dont know how much compression I've got going by psi. Anybody have any conversions or ideas?
Old Mar 7, 2002 | 11:43 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
there is no conversion for this. too many variables.
Old Mar 8, 2002 | 07:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, there is a way, but you have to know the volume when the piston is down all the way, and the volume when the piston is up all the way.
But, if you know the volume when the piston is down all the way and the volume when the piston is up all the way, you don't need to know the cranking cylinder pressure to figure out the compression ratio, because the former divided by the latter IS the static compression ratio...
Old Mar 8, 2002 | 07:56 AM
Beast4's Avatar
What zippy said.
Old Mar 8, 2002 | 08:59 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Only way to tell for sure is to measure before the engine is put together, different cam duration's and designs greatly affect the cranking compression. But 185 PSI is very good so I don't think I would worry about the real ratio unless it pings badly with the correct ignition timing.
Old Mar 8, 2002 | 10:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is no way to create an equivalence, for a number of reasons. One, the valve timing affects how much of the static compression remains "captured" in the cylinder, which causes the reading to be lower than it otherwise might; and two, when you compress a gas it heats up, which raises the pressure beyond the static amount (if you could compress the cyl and let it cool back down this error would go away but obviously that's not practical) which makes the reading much higher.
But, 185 psi is good, if all cyls are that. One cyl that high probably means a bad intake cam lobe, loose valve, or other cause of short intake duration. Look for consistency in compression readings, not the absolute value.
So, like the other post said, too many variables.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
FormulasOnly
Jul 23, 2018 08:47 AM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Damon
Sep 26, 2015 04:29 PM
