Custom Carb intake modified with TB Help!!!
Old Mar 12, 2002 | 04:45 PM
JucinGTA's Avatar
K I know one guy has it in here were you modify a carb intake with injector bongs and the actually have a piece made were you can adapt a normal TPI TB to it. Does anyone know who does this?:lala:
Old Mar 12, 2002 | 05:03 PM
Jester's Avatar
I've seen alot of people that have done that. I forget who sells it now tho...
They don't use TPI TB's. Most people buy an elbow that bolts to the carb flange and goes to a mustang TB usually. They're cheaper and have alot more options.
Old Mar 12, 2002 | 05:20 PM
JucinGTA's Avatar
Sweet!! Anybody have any links?
Old Mar 12, 2002 | 06:25 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Accel makes one.I made my own took a TPI plenum cut it half behind the throttle cable bracket.Cut out a hole in the bottom of the plenum using a carb gasket as a template.Got a 2in carb spacer welded it to the bottom of the plenum also welded a plate to the back of the plenum where I cut it in half.Made a plate to bolt to the other side of the plenum that I drilled and taped for the vac lines.Its 5in tall and cost me $150 with the welding VS. accel's $250-$270
Old Mar 13, 2002 | 05:07 PM
JucinGTA's Avatar
Ya Im actually looking for the other style, damn I wish I had a pic.
Old Mar 13, 2002 | 08:45 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You might wanna try www.wilsonmanifolds.com. They can convert a carb intake to EFI and also sell a TB adapter that I *think* uses a Mustang TB. Also force fuel injection, www.force-efi.com, has the converted intakes. I looked into these options but decided against it because I did not want to use a cowl induction hood.
Old Mar 14, 2002 | 11:29 AM
JucinGTA's Avatar
Sweet Thanks!!!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
