Is this normal?
Old Mar 13, 2002 | 07:38 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Is this normal?
Something wierd happened with my camaro today. Today at lunchtime, I took the car to the body shop, the motor was running maybe 90 seconds, did my business at the shop then went back to work, again the motor was not running more than 90 seconds, and it was stone cold when I started it.
Heres the wierd part, by the time I got back to work, the radiator was fully pressurized, and the top hose was rock hard yet it was still cold.
Could something be blocked somewhere? The kid I bought the car from says the radiator is brand new, and so is the thermostat.
Sorry to be so long.
Thanks, John
Old Mar 14, 2002 | 07:36 AM
Vader's Avatar
John,
Even though the thermostat had not yet opened, the coolant in the engien would have warmed to the point of creating pressure. The pressure may not have been high enough to make the hoses "rock hard", but there should have been pressure.
If the pressure is excessive, you may have a gasket leak, allowing compression pressure into the cooling system. A quick compression or cylinder leakage test would be an easy way to determine that.
Old Mar 14, 2002 | 08:23 AM
Thanks Vader, I'll have that looked in to.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
