IAC gasket?
Old Mar 14, 2002 | 04:17 PM
BTS88IROC's Avatar
IAC gasket?
Where does everyone get the IAC gasket? It doesn't come with the throttle body gasket and I don't remember how I got one last time. I think it came with a different kit or under some weird name. I remember I had to order it though. Anyone?
Old Mar 14, 2002 | 09:46 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Well this will probably kick you in the pants but the part only comes in a kit. This is the info for my 86 T/A
17113115
Gasket Kit - Includes the IAC Gasket, the Lower Cavity and TPI Plate gaskets.
This is basically a kit to totally service the Throttle Body. Believe me I searched for the IAC alone and as far as GM OEM gaskets it just wasn't available.
Old Mar 14, 2002 | 10:07 PM
cort351w's Avatar
I need an IAC gasket also. What is a lower cavity--coolant passage on bottom of TB? It the TPI plate the TB plate? If so, I don't remember taking a gasket off of the plate when I took it off and the car has never been taken apart before.
Old Mar 15, 2002 | 09:52 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Yes the top plate has a gasket. As well as the coolant cavity. It is a good idea to get the kit and split your TB apart. There is usually a bunch of crud and corrosion in the cavity.
This kit allows you to refurbish the TB and reseal it.
Old Mar 15, 2002 | 10:40 AM
BTS88IROC's Avatar
Is that part number you gave a dealer #??
Old Mar 15, 2002 | 12:31 PM
cort351w's Avatar
Does Fel-Pro (or someone else) make an equivalent gasket set? I'd rather go buy it at the parts store than wait forever for a dealer to order the part.
Old Mar 15, 2002 | 01:07 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
To the best of my knowledge this is a dealer only item. The part number is for an 86 T/A.
I can't imagine the part numbers being different but I would check for your specific application to be safe.
Old Mar 15, 2002 | 10:55 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I couldn't find it anywhere but at the dealership in a kit. I'd already taken the IAC housing off the throttle body and mutilated the old gasket, but was too cheap to buy the whole set for one gasket. Instead I made a gasket out of RTV for it, and it apparently worked fine. Although I have the coolant TB bypassed so it's not as much of an issue for me.
Old Mar 16, 2002 | 01:48 AM
cort351w's Avatar
Yeah, I'm bypassing the TB as well, but I wanted the IAC gasket. VisciousZ, did you connect up the stock hoses or use a new piece? I read in the tech article to buy a section of hose with a 90* bend so I did. At this point (with my intake off the car and a lot of other stuff taken apart), I'm not sure that the 90* was the best option, but I've seen that many places so that's what I bought. I guess I'll see when I start putting it back together.
Old Mar 16, 2002 | 11:38 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Actually for my TB bypass, I used a formed hose, not just a 90º bend. It had a straight part, and then a sort of U shaped bend. I work at a parts store, so I was able to just dig through all the formed hoses until I found one that was the perfect shape. It was a Gates hose, but I can't remember the part number. I'll be doing the bypass on my new GTA as soon as I get it, so I'll find the part number then and post it on my webpage.
Old Mar 16, 2002 | 11:40 PM
cort351w's Avatar
VisciousZ, are you anything like Vicky Vallencourt on the Waterboy? Sort of random, but I saw that movie tonight and thought about it when I saw your post
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
