Coolant drain from block
Old Mar 14, 2002 | 05:33 PM
Fred91GTA's Avatar
Car: 1991 GTA
Hi guys. I have to drain coolant from my engine block. I know there are two coolant drain plugs at the bottom of the engine. When I get them back on, do I need to use a thread sealer? If so, what type do I need? Thanks.
Old Mar 14, 2002 | 06:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
None needed. Teflon tape not a bad idea, though. Or, sensor-compatible silicone sealer.
Old Mar 14, 2002 | 06:47 PM
Vader's Avatar
For those plugs, standar old PTFE tape or joint compound will work fine - they're tapered pipe plugs. Of course you can use Loctite PST if you don't have the Teflonē tape or paste.
Bubbajones_ya
Jul 6, 2024 08:32 PM
89 formula TPI
Oct 6, 2015 08:40 PM
ericjon262
Sep 11, 2015 06:07 PM
FormulasOnly
Sep 10, 2015 09:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
