Tire Leaks
Old Mar 14, 2002 | 08:14 PM
iroc_cragg's Avatar
Tire Leaks
Hey
I have a 1985 IROC Z Camaro. The front drivers side tire has a slow leak in the tire. The leak is not caused by the tire itself but from the valve stem.... How do I fix it.
thanks
http://camaroz28.cardomain.com/id/56424
Old Mar 14, 2002 | 09:09 PM
CODY BEHNKE's Avatar
New rubber valve stem or get the bolt in type.
Old Mar 14, 2002 | 09:48 PM
iroc_cragg's Avatar
Isnt there away that I can just tighten it or somthing
Old Mar 14, 2002 | 10:02 PM
Blackened's Avatar
You take it to a tire shop and have them fix it !
Old Mar 14, 2002 | 10:13 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
There are valve core removal tools that will tighten it up. Ive seen then at walmart for a few bucks.
Old Mar 14, 2002 | 10:30 PM
2vmodular's Avatar
sometimes the aluminum becomes pourous or develops small cracks over time and the rim itself leaks.
Old Mar 15, 2002 | 07:42 AM
82camaro's Avatar
Car: 82 camaro SC
Depends, is it around the stem, or from the valve core itself. If it's the core leaking, go buy the tool. Take the core completely out, clean it up, put a little bit of dish soap on the seal and put it back in. Most tire shops should do that for free if you ask nice. If it's from around the stem, the tire will have to be taken off and a new stem put in. Where I used to work it was 3.50 for a mount and 1.75 for a stem.
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
SG91camaro
Sep 5, 2015 10:27 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
