Will a Compucam 2020 destroy my top-end?
Old Mar 16, 2002 | 01:14 PM
Golden80's Avatar
Just wanted to see if anyone had opinions on Cranes CompuCam 2020. I'd like some more low-end grunt from my car and thought it looked to be a good choice. I just don't want to completely destroy my top-end though.
Thanks,
Matt
Old Mar 16, 2002 | 05:37 PM
DM91RS's Avatar
Car: 91 RS
What are you wanting to install this in?
Old Mar 17, 2002 | 02:33 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
what are you currently running?
Old Mar 17, 2002 | 06:46 AM
Golden80's Avatar
Sorry about that. It's an LG4 305 with a CC QJet. Everything in it is still stock right now.
Old Mar 17, 2002 | 07:01 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I have a 2020 Roller cam in my car and it has a better low end than stock and pulls great to about 5500 RPM but I also added headers and did a port and polish on the stock heads at the same time.
Old Mar 18, 2002 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Golden, you really need a ride in my car. Low end grunt - no problem!
Using the 2020 would be making the same mistake CHP Mag did on the My Generation Camaro - too little cam, too low stall speed. You get low-end grunt with higher stall & taller gears. The only issue with a bigger cam, as far as your top end goes, is springs - you'd want new springs with a 2020 anyway, so just get springs to match a higher lift! (Longer slot rockers another possible issue.)
In order to get all the benefits out of a larger cam (including the 2020), you'll need to the upgrade exhaust (and air cleaner, if you haven't done that yet). Do that first, then the cam.
Old Mar 18, 2002 | 04:56 PM
five7kid's Avatar
Wait a minute, were you talking about "top end", as in valve train, or "top end", as in power band?
If the former, then the spring answer I gave above applies.
If the latter, even the 2020 will be better than the LG4 peanut, but it will be less of a gain than with say a 2040 or 2050.
Old Mar 18, 2002 | 07:58 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Or a Comp Cams XE 250 or 256 cam. The Crane 2020 is just too small, hardly much of an improvement, as Five7kid says.
Old Mar 19, 2002 | 09:45 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
What about the 2040?
Old Mar 19, 2002 | 01:51 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Don't go with anything smaller than the 2030 for absolute certain. You'll be wasting your time if you do. I ran the 2030 in my 86 305 TPI and liked it. (I re-used all the stock stuff except the lifters BTW, has worked fine for a couple years so far. Don't know what's different between the LG4s and LB9s spring wise etc, though). I ran that cam with very few other mods to start with also, was just fine. You will want some headers and junk down the road though.
Also, while your intake is off for the cam swap do yourself a favor and throw a Performer intake on there. Easy extra power, cheap and it'll work well with the new cam...
I'm kinda torn over whether or not the 2040 would be better though, didn't try it so I can't say for sure...
Old Mar 19, 2002 | 01:53 PM
99Hawk120's Avatar
Well, at some point we'll know, since a friend is running the 2040 in his 86 305 TPI TA.
FormulasOnly
Jul 23, 2018 08:47 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
