on a 14x3 dual snorkel air intake,how much is air flow hindered with a 1/2" drop base
Old Mar 17, 2002 | 08:51 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
is worth worrying about? i know it drops the filter down a slight bit and then the incoming air has to flow over the 1/2" bump up inside b4 emtering the tbi..........gimme your thoughts
Old Mar 17, 2002 | 02:04 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
you shouldn't lose any from the last test i seen. i believe it was car craft or hot rod did an air filter test and the one that suprisingly did the best was the drop base air cleaner. not that it says the drop base is the best, but i wouldn't expect any loss due to it.
Old Mar 17, 2002 | 08:13 PM
wasp's Avatar
must have been hot rod i get car craft dont recall that, ok thanx for the info
Old Mar 17, 2002 | 08:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Doesent a non drop base fit? It should.
SSC
Old Mar 17, 2002 | 10:59 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
No, it is in the current Car Craft.
Old Mar 18, 2002 | 05:26 PM
wasp's Avatar
i stand corrected it wasnt on the cover tho.........
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
