Check engine light comes on when I gun it.
Old Mar 18, 2002 | 08:08 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I found some code from the computer it blinks on-off-on. Well I tried looking for that code and I cant find what it means
Old Mar 18, 2002 | 08:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
what was teh code #?
Old Mar 18, 2002 | 09:30 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Do you know what the number is? If you ground A/B and (after the 1,2 - 1,2 - 1,2) you get 4,4 - 4,4 - 4,4 - that code 44 means lean reading from O2 sensor) - if that's the case, it's either b/c (1) you're lean at WOT (need to boost fuel pressure; maybe fuel pump is going out -0-->major bummer!) or (2) your O2 sensor is shot/not making good electrical contact...
(just a guess)
maroe624
Apr 16, 2017 08:29 AM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
