What grits do i use to polish...
Old Mar 19, 2002 | 03:36 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
what various grits should i use to polish my rims. stock 90 RS rims.....im gonna scrub off all the black, smooth em out and polish em up....cuz they are all jacked up from doing donuts on the beach in cali.
any help appreciated.
BB
Old Mar 19, 2002 | 03:44 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i assume the black you mean is tarnished? id use blue magic over and over...its the best aluminum chrome polish there is......search for it on the internet blue magic polish corp in santa ana ca......
Old Mar 19, 2002 | 04:12 PM
Car: 90 Camaro RS
Engine: 305 TBI
no....the rims are originally painted black...i want to use sandpaper to remove it and eventually have a presentable finish. i was thinking of starting with 180 to 320 to wet 400 to 500 and so on.
Old Mar 19, 2002 | 04:24 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'd start with the 320 and move up from there for a smooth surface to paint. I'm assuming that it's just the paint that's in bad shape and not the rim itself?
Old Mar 19, 2002 | 05:48 PM
89blackbird's Avatar
I have been doing this for a few weeks now and here's what works for me. First clean the wheels with good soapy water to get all dirt ,oil and film off. Next blow dry them off good. You can use stripper to take off the old paint and any clear coat which may be on. If there is clear coat and you decide to sand it off it will take alot of work. DO NOT WET SAND. I started with 320 grit dry going around in a pattern, next 400 grit dry, stop and wash wheel again with good soapy water rinse and dry. Now 600 grit then 800 grit. Now I stop and clean with an aluminum cleaner bought at NAPA. Works great for deep cleaning.Spray it on wait 1 minute and hose it off.(wear gloves it is an acid) this will cause the wheel to turn a light milky color. Dry the wheel off and paint the painted areas.now final sand with 1000 grit the polished areas. Last step is to use never dull polish followed by mothers polish and rub it in . The more you polish the better it gets. Good luck
Old Mar 19, 2002 | 07:54 PM
Car: 90 Camaro RS
Engine: 305 TBI
why not wet sand....i was told to do a 400 wet.
i plan on goin to 2000 grit....probably.
i dont plan on repainting, just polishing.
the rims are damaged themselves, so a very coarse grit will be needed at first i suppose.
thanks
Old Mar 19, 2002 | 09:16 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
thanks
here's what i did to my ta wheels. first i used roloc pads on my grinder to get the clearcoat off. then i hand sanded with 320, then 600, then 1000. all dry. after that i used a high speed buffing wheel on my die grinder to get this final look:
and this picture was taken inside a building. imagine what they look like in the sun!! sorry no pic of that.
Black Beauty
Mar 19, 2002 10:16 PM
BigMike92Z
Jan 28, 2002 09:50 PM
Black_Widdow
Jan 18, 2002 03:33 PM
Rob90TA
Jul 26, 2001 07:16 AM
JoelOl75
May 16, 2001 07:20 AM
